Multi-tenant central directory
Luca Moerenhoudt
We currently have a multi-tenant setup where a couple of our clients are provisioned on.
The issue that we are facing is that the path of the central directory of the Snom900 is to the "snom_phonebook.xml" file which is currently empty for some reason.
Which means that all the Snom DECT points are pointing to an empty central directory.
Temporary solution would be to create a specific xml file in the PBX but when rebooting or re-provisioning a DECT point, the configuration file it retrieves points back to the "snom_phonebook.xml" file (if you copy the provisioning link of the DECT in the PBX and paste it in the browser, it gives you that config file).
This is also a static solution I'm assuming, but I haven't had the chance to test this yet.
Wat is the best dynamic way to set this up so that even if name changes or users get added, the central directory automatically gets updated for that department/client?
Thank you!
Reactions: N_G
Phonebook disabled on phones in multi-tenant.
Wait for per-department phonebooks (on the roadmap, no ETA.)
arming
