Solved Multiple Backups with only one scheduled job and phantom automated reports
illcs
This is happening on two installs both Debian cloud hosted, one Azure, one LightSail. 3cx ver 18.0.237.
The report generation was brought to our attention about two weeks ago so we went in and modified (rebuilt) the report settings. This appeared to be fixed until this week. What is odd is the reports are showing reports for future dates previously if was for old dates, but report settings are for last week. This install also is generating multiple back ups for the nightly backup at 8:00, 12:15, 12:29 all on the 16th. No failure errors and the size is consistent.
The second install does not generate reports but it does do backups with similar results as the system above. 9:00,9:43,10:26.12:00,12:43
We have rebooted the system verified the time just incase it was caused by drift but the ntp is correct.
Any ideas?
apbGroup
