- Joined
- Sep 21, 2018
- Messages
- 16
- Reaction score
- 0
I suspect I am missing something minor or this is just not a supported configuration.
Client has 3 small businesses, each has a separate DID/mailbox 555-888-1234 -> ext 500 and 777-333-4321 to ext 600
Both extensions have the DID assigned to their respective extensions with a voicemail configuration
The physical phone device, has the two lines added to the BLF as BLF monitoring
The extensions have a forwarding rule * to forward to the physical phone with extension 200
What works:
Any calls coming into the two DID's are routing to the physical phone correctly, based on the forwarding rules of the extensions
What doesn't work:
When the call goes unanswered, it dumps into the physical phones extension (200) voicemail instead of falling back to the originating extensions voicemail
The solution desired:
User wants to receive calls from multiple DID's routing to his phone and absent his answering, have those calls fall back to voicemail for the originating extension
Added perk:
When the incoming DID to extension rings to the physical phone, having the extension name displayed to allow him to know which line it is coming in from
What works:
What doesn't work:
Added perk:
- 3CX Version,18 Update 3 Build 461
- Server OS, Hosted 3cx
- Is the 3CX Server Hosted and where? Yes, hosted by 3CX
- IP Phone Make/Model/Firmware version, Yealink T48S, 66.86.0.5
- Provisioning Method: SBC
- Trunk Provider or VoIP Gateway Make/Model, Flowroute
- Has the Firewall Checker passed: Yes
- Are custom Phone Templates being used: No
