Solved Multiple NICs
Yhe
Platinum Partner
Does 3CX support officially 2x NICs on a VM (Windows OS) ?
If we call support for a problem, do they support us in this configuration ?
BR's.
Yoann.
As per the documentation @Saqqara linked to, it is supported in those network configurations. just make sure that the 3CX PBX only uses one for the internet traffic hence only one of the NIC's has a default gateway.
Hi All,
Thanks for your repply.
BR's.
Yoann.
Reactions: ChrisC_3CX
No worries!
Feel free to start a new thread should you need additional information or assistance!
mazet
