Multiple Outbound Name Display
skycomp_serge
I have a client that operates 2 different brands out of the same location and phone system.
I can direct different DID's to different Automated Attendants. As well for outbound calling I can assign certain extensions a different outbound DID.
What I can't figure out is how to set multiple outbound name Displays.
Is there a way to do this?
I had just assumed that would have been a setting on the Outbound Rule but I see I can only set Name Display on the SIP trunk but I only have 1 SIP trunk for the client that carries calls for both companies.
Thanks.
Are you in Canada or some other country that allows you to push the name? Because you can't in the US. But either way, you would still need two trunks.
Yes we are in Canada so we can push the name.
Wecare_ITA
