Multiple Trunks via different providers
crspangle
New User
Merry Christmas! I am testing the Startup and I would like to have multiple trunks via Skyetel & Voxtelesys so that I have some reduncnay but it looks like it is not a feature of the Startup program. Is there a workaround for this? Also the new feature to add IP phones is awesome!
Reactions: sweetgoodbye
Hi there, and Merry Christmas to you.
Currently, there is only an option for a single trunk per startup instance, within which you may have multiple DIDs.
Hi All, I would like to use both a US trunk and an Australian trunk with our Startup Pro instance - I understand that only 1 trunk is currently available but is it possible that future versions will allow 2 trunk sips? Or is there a work around to enable callers from more than one country to be ported to the 3CX instance.
If you need a complex system with many providers, you should be using a dedicated system and not StartUP.
Reactions: YiannisH_3CX
Isuru Eranga
