Multiple Yealink W60B install
RymCo
We currently have a 1x Yealink W60B base with 2x RT30 repeaters and 8x W56H DECT sets. We need to add more cordless extensions but we've maxed out the single W60B. Would there be any issue with just purchasing another W60B and repeaters and install in the same coverage area? I realize the sets will only roam between the base and repeaters they are assigned to. Just not sure if they'd interfere with each other...
I see there is now a Multi-cell W80B. That would have been my choice from the start but we just need to add a few more DECT sets now.
You will be fine on the extra W60B base units, not sure about the repeaters.
Do you associate the RT30 to a W60B base unit ? If you do I can not see any issues.
The main issue to note with the Yealink DECT range is that they do not support multi-cell mode (unlike the supported snom M700 range): https://www.3cx.com/sip-phones/snom-m300-m700-dect/
What these means is with multiple base stations you cannot roam between them with an active call.
Reactions: CentrexJ
The repeaters are associated with my current W60B. If I add another W60B, I would grab another 1-2 repeaters and associate them with the new W60B.
I know the handsets can't roam between the 2 bases... they're basically separate DECT installs.
Wecare_ITA
