ProcessorCount = 4What is the system spec?
Only when it comes via trunk.2. Whatever Android or desktop iP phone some issues, blind transferHi please give us a description (as detailed as you can) on how the transfer is done so we can understand what plays the music and why.
Example
1. call comes in via trunk going to DID assigned to ring group
2. user answers on webclient / ip phone / mobile client
3. what user presses to complete the transfer
ld name="IpInContactReg">1</field>We would ideally need a bit more info, but here is a quick check you can do for now:
1. Click the 3 dots next to your trunk and export it.
2. Open the file and check these parameters:
<field name="IsSupportReinvite">0</field>
<field name="IsSupportReplaces">0</field>
3. They should have a zero like my example. If they have a 1 it can potentially cause the problem you described.
Can we check this first?
perfect its work Thanks so muchI think we can solve this by changing <field name="IsSupportReinvite">1</field> to zero like below
XML:<field name="IsSupportReinvite">0</field>
1. You will have to edit the exported trunk file to change this value.
2. Take a backup of your PBX to be on the safe side.
3. Then delete the trunk, and import the file we just edited
4. Once imported, you will have to assign your trunk to the same destination you had before.
5. Now make a test and perform some transfers and let us know if this fixed the problem.
If anything goes wrong, you can simply restore the backup
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
