Need get peer adjustment
Artem Khvostenko
New User
My SIP-provider ask me peer adjustment, example
sip.conf
register = tls://380931700000:PASSWORD@сsbc.lifecell.ua:5061/380931700000; (RTP)
[380931700000]
type = friend
insecure = port,invite
username = 380931700000
secret = PASSWORD
host = сsbc.lifecell.ua
port = 5061
transport = tls
encryption = yes
context = fromLifecell
disallow = all
allow = alaw
allow = ulaw
Where I can get it?
If I will export provider from SIP trunks - I have not enough info.
Please help
Hi @Artem Khvostenko
Your provider gave you a config that is most likely for Asterisk or something Asterisk based.
What do you want to do exactly in 3CX?
We have a configuration guide for Lifecell. Have you tried that?
Reactions: Artem Khvostenko
Make sure you are running Minimum 3CX Version: 3CX v18 Update 4, as per info the above url
Hi, I have updated, but can't see this type of trunk - lifecell
Under updates, do you see any updates ?
If you are on Version 18 Update 4 you should be seeing something like this:
If you do not try clearing your cache or try a different browser.
postmaster@studiolegaleda
