Solved Need help with SBC installation
dipesh09
We are using hosted 3CX and I have one SBC running at our head office and working fine but we also have 2 more locations. I am getting SSL certification error while installing SBC on both remote locations. I am installing it on our windows server (Domain controller). Also, all 3 locations are connected with VPN. I am able to open the 3cx webpage on both remote locations. it is also resolving FQDN. not sure what to do next or how to get that certificate.
Solution
Thank you guys. I am able to installed it on Windows server 2022 STD without any issue. So, looks like it is not accepting 2012 R2.
Is it a custom FQDN or a 3CX FQDN? If custom, check using https://www.ssllabs.com/ssltest/ or similar to see if the certificate is valid, not missing an intermediate cert, etc.
Hi, if you're working with a partner, could you ask them to open a support ticket so we can look into this on our end? open
Hi @dipesh09 if the pbx is hosted with us, ssl certificates from the pbx side should be ok, this could be more in the machine used for installing the sbc, what OS are you using? if this is a windows machine, please make sure it has all the updates installed.
Review the expiration date of the certificate in the pic below
I am using windows server 2012R2 std. I checked the certificate and it has validity till 2035.
PLease try to use a supported Windows version
  • Windows 10 (Pro, Enterprise)
  • Windows 11 (Pro, Enterprise)
  • Windows Server 2016 (Standard, Datacenter)
  • Windows Server 2019 (Standard, Datacenter)
  • Windows Server 2022 (Standard, Datacenter)
  • Windows Server 2025 (Standard, Datacenter)
Reactions: dipesh09
@dipesh09 An alternative option could be to configure Hyper-V and install a Linux SBC, which would then be portable (or install one with the same IP on another server). But ESU for 2012 ends next month so moving off 2012 is obviously the best idea.
Start by telling us the exact SSL error message from the SBC installer, so we could narrow it down to the specific fix.
Maybe a DNS resolution error and you're getting a mismatch?
Check that when you ping the FQDN of your 3CX as these locations, it returns the WAN IP of your PBX?
Reactions: Alejandro_3CX
Solution
amazingbv
