- Joined
- Aug 4, 2009
- Messages
- 404
- Reaction score
- 52
yuck yuck yuck. I found it.
So, when selecting the inbound route, there are multiple entries shown because the DID is in multiple trunks. If I don't select the DID that matches trunk 1, it doesn't work.
so, did 1 and 2 are both on trunk 1
when I add the inbound run and select did1's first copy I get an entry showing trunk1. this works.
create did's inbound route selecting trunk1's copy and that works.
delete that and recreate did 1's entry but select the second entry and it the matching no longer works.
This effectively means that I have to have an inbound route entry for every trunk+did.
ie, inbound routes for
trunk1-did1
trunk1-did2
trunk2-did1
trunk2-did2
except there are 5 inbound trunks and if I have 15 DIDs to route that's a gigantic mess.
So I think this comes down to the GWHostPost entry. I think that needs to be something else, specifically something that doesn't use the gateway IP for identification because I want the inbound routing to 'float'
trunk1-did1
trunk1-did2
trunk2-did1
trunk2-did2
