  • V20 Update 10 RC Learn more
Need Solution for ring group second lines on V18
Nuagix
I need to know if anybody have a solution on reception ring group on second line for new v18
Steve
Do you mean adding a second line appearance to a receptionists set, or... exactly what?
On v16 ,i can change the config allowacceptcall to 1.On v18 i dont see this feature.My customer receive the inbound call on ring group with 4 phones.When the reception receive the first call , she cant take the second call if the first is always on.Only on different phones on the ring group.
This is not a supported function.
- You can either use a combination of call queues and shared parking
- Or you can skip the ring group, and assign all 4 users the same extension. Enable multiple calls on the extension and send all your calls there
Graham Robertson
