Need to redeploy the PBXexpress
Tushar Jain
Yesterday I deployed 3cx on AWS but it seems I need to install it again as need to set it on a different VPC
Wht should be the process, can i terminate the present one and start a new server
Hello @Tushar Jain
Please note that you can delete the one you currently are running and use the PBX express to install it on a different instance. If you need your configuration just create a backup from the current system without including licence and FQDN information and restore it to the new instance after the installation is done.
Thanks Yiannish for your reply
I have another question for you
I am trying to reinstall the 3CX manually on debian 9.5 but getting following error
root@ip-10-20-30-117:/home/admin# apt-get install 3cxpbx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: libssl1.0.0 but it is not installable
Depends: libicu52 but it is not installable
Depends: libcurl3 (< 7.39.0) but it is not going to be installed
Conflicts: libssl1.0.2 but 1.0.2l-2+deb9u3 is to be installed
E: Unable to correct problems, you have held broken packages.
root@ip-10-20-30-117:/home/admin# apt-get install libicu52 libssl1.0.0 libcur
Do i have to install it via 3cx system only?
Hi Yiannish,
I agree its better to use 3cx iso but my issue is I am using AWS so cant use the ISO
secondly need to install it in a specific VPC but cant able to do so while installing it from 3cx site
Is there a way to assign the instance to a specific VPC or not
Regards
Tushar
Thanks Yiannish
I was able to deploy the 3cx manually via the link you send and its working fine
I have another question do there is way to set up for the persistent conferences
I recently deployed the 3cx and was earlier using Asterisk
User not ready to create new conference rooms when ever they set up a meeting, specially if the meeting is on weekly basis
Regards
Tushar
Are you talking about audio or video conferences?
Zexus
