New issue with Hosted 3CX and SBC on Debian
john.barnhill
Today at around 1PM I noticed our Debian SBC went offline in the 3CX admin portal. I logged into the SBC and found it was running and able to ping Google. I rebooted and checked for updates and got a green message that the SBC was running successfully however it remained offline in 3CX admin portal. I am not able to ping the hosted 3CX server from the SBC but I am able to resolve it via a trace route. I don’t see the SBC IP blocked in the 3CX firewall so I am not sure what else to do. It is worth noting we put a public IP address on the SBC last Friday, but otherwise has made no changesIMG_4252.jpegIMG_4253.jpeg
If the SBC IP changed you might need to remove and add it again on the PBX.
I tried this and it remains offline in the 3CX admin portal. Is it OK to have a public IP on the SBC or could that be the issue?
As long as the routing works, it shouldn't be a problem. From the SBC, can you telnet to 443 & 5090 on the PBX?
Hello john.barnhill,
Maybe your internet provider has implemented IPv6 and the routing will follow this IPv6 ?
This can also be on the DNS with preffered IPv6 or something like this.
Try to add the IPv4/FQDN to the hosts file on the SBC, see if this will resolve the problem.
Paulo
Reactions: KyriacosS_3CX
We had to create an allow rule in the 3CX firewall and it came back online
xDxD great its back.
tom.walker@blackcountryra
