New SMB instance (in Azure) - Can't login?
jackyN
SOHO User
deployed a SMB instance in Azure following the guide (https://www.3cx.com/docs/pbx-azure-marketplace/).
I have uploaded right configuration and the process are all done and dusted. Worth noting that it sends me to update the password which I did
Then it send me to <my_fqnd>.3cx.com.au/#/login
This is where it all falls apart. I tried every possible way to login and even tried to reset my password via my email - didn't work.
I can login to my 3cx portal where I can see the my 3cx instance with greenlights showing it's online.
How do I actually login or maybe reset my password?
SMB is not something you can install. Did you buy a license? Trial?
Thank Steve
I did deployed a SMB version in Azure which is available for free that I know of. Don't think is a time limited Trial. I could be wrong but this is what I see in my 3CX portal.
Hmm that shows as a one year Basic license but 4SC which I didn’t think was available, at least the last time I looked.
Anyway, the default login is ext 100 but requires a unique email address (in this server) to do a password reset. But you said it’s a new server. If the email was invalid and bounces, the 3CX SMTP will block it for a week as I recall. Could that be it?
That is the new free pbx, but not the smb. Smb is only hosted by 3cx and different from the free pbx.
No members online now.
RJenkinsROCK
