New to V20- Simple Questions
jgoz
Hey All- getting ready to upgrade all of our clients to V20, and just have a few Simple questions.
Will we still need to add :5001 to the end of the FQDN to access the webclient?
The reporting looks a bit different, and I know each user can set up their own, but can a manager create a report that is emailed to a group of other managers for their team?
For reports, can we specify the days the reports are run (reports not needed to be run or emailed on Saturday and Sunday)
Is there an option to Not send the welcome email on extension setup?
Thanks- Looking forward to playing with all the other new toys-
If you are using it, it is recommended so your users dont notice the difference. If you want to ditch 5001 and migrate to 443, you can do so. Just tell your users to refresh their bookmarks. You will also need to reprovision any IP phones with the new URL, without the port.
This will be possible with update 3, which is currently as an Alpha release.
Weekly reports are sent on Monday. Daily reports are daily, weekends included.
Yes there is.
awesome- thanks so much
Reactions: NicholasP_3CX
mike.carter.991
