!!!NEW UPDATE!!! 3CX Phone System + 3CX Assistant V8
nb
Support Team
Hi 3CX Community!
We are pleased to announce a new Version 8 of the 3CX Phone System and 3CX Call Assistant.
Download 3CX Phone System Version 8 from here
Change log available here
Download the new 3CX Assistant Version 8 from (no longer available) here . This also includes the latest 3CX Phone and a new 3CX Tapi Driver
We Look forward for your feedback.
Nicky Borg
Re: !!!NEW UPDATE!!! 3CX Phone System + 3CX Call Assistant V8
Yes we will see what we can do about the first problem - We might make a scrollbar or something.
About the second problem - What do you mean broken?
We cannot know the number of contacts in your exchange at this point - we are searching for public contacts folder here at this stage not for individual contacts.
Prepare that with 10000 contacts, the polling search may take a while.
We updated the 3CX Call assistant available from here
http://www.3cx.com/downloads/3CXAssistantSetup80_10903.exe
This version is at the moment available only from the forums.
Nicky, I am sorry, but I not fully understood Active Call Limit string. What these numbers means?
Quantity of active calls or what? So why this is not one number? For example - Active Calls - 35. (I.e. currently I have 35 sim. calls).
Hi no problem - I will explain.
Example: Active call counted towards license limit - [35]
This 35 means that CALL number 35 is the call that is at the moment connected - ie only 1 call is connected - call number 35.
We are going to improve this message in the next version to something like this
Current connected calls [5 - 1, 35, 36, 99, 102]
This will be interpreted as
there is a total of 5 connected calls at this moment
These 5 calls are call number 1, 35, 36, 99 and call 102.
Remember - each call that is made in 3CX is assigned a numerical number in ascending order.
So everytime you restart the service, and you make the first call, this is call number 1. This value increments by one with every call that is made UNTILL the next restart of the service / or computer. Only then the calls go back to 0 and the counter is reset.
hope this is clear.
I have a system that has had no calls happening at all for the last few hours but this is in the log
20:37:37.678 Active calls counted toward license limit: [571,573]
20:37:05.679 Active calls counted toward license limit: [571,573]
20:36:33.680 Active calls counted toward license limit: [571,573]
20:36:01.680 Active calls counted toward license limit: [571,573]
20:35:29.681 Active calls counted toward license limit: [571,573]
20:34:57.682 Active calls counted toward license limit: [571,573]
20:34:27.636 Active calls counted toward license limit: [571,573]
20:33:55.637 Active calls counted toward license limit: [571,573]
20:33:23.638 Active calls counted toward license limit: [571,573]
20:32:51.638 Active calls counted toward license limit: [571,573]
20:32:21.623 Active calls counted toward license limit: [571,573]
20:31:49.624 Active calls counted toward license limit: [571,573]
20:31:17.625 Active calls counted toward license limit: [571,573]
20:30:45.625 Active calls counted toward license limit: [571,573]
20:30:13.626 Active calls counted toward license limit: [571,573]
20:29:41.627 Active calls counted toward license limit: [571,573]
20:29:11.612 Active calls counted toward license limit: [571,573]
20:28:39.613 Active calls counted toward license limit: [571,573]
20:28:07.613 Active calls counted toward license limit: [571,573]
20:27:35.614 Active calls counted toward license limit: [571,573]
20:27:05.599 Active calls counted toward license limit: [571,573]
20:26:33.600 Active calls counted toward license limit: [571,573]
20:26:01.601 Active calls counted toward license limit: [571,573]
20:25:29.602 Active calls counted toward license limit: [571,573]
20:24:57.603 Active calls counted toward license limit: [571,573]
20:24:25.603 Active calls counted toward license limit: [571,573]
20:23:53.604 Active calls counted toward license limit: [571,573]
20:23:21.605 Active calls counted toward license limit: [571,573]
20:22:49.605 Active calls counted toward license limit: [571,573]
20:22:17.606 Active calls counted toward license limit: [571,573]
20:21:45.607 Active calls counted toward license limit: [571,573]
20:21:13.608 Active calls counted toward license limit: [571,573]
20:20:41.608 Active calls counted toward license limit: [571,573]
20:20:09.609 Active calls counted toward license limit: [571,573]
20:19:37.610 Active calls counted toward license limit: [571,573]
20:19:05.610 Active calls counted toward license limit: [571,573]
20:18:33.611 Active calls counted toward license limit: [571,573]
20:18:01.612 Active calls counted toward license limit: [571,573]
20:17:29.613 Active calls counted toward license limit: [571,573]
20:16:57.613 Active calls counted toward license limit: [571,573]
20:16:25.614 Active calls counted toward license limit: [571,573]
20:15:53.615 Active calls counted toward license limit: [571,573]
20:15:21.616 Active calls counted toward license limit: [571,573]
20:14:51.601 Active calls counted toward license limit: [571,573]
20:14:21.586 Active calls counted toward license limit: [571,573]
20:13:49.587 Active calls counted toward license limit: [571,573]
20:13:17.588 Active calls counted toward license limit: [571,573]
20:12:45.588 Active calls counted toward license limit: [571,573]
20:12:13.589 Active calls counted toward license limit: [571,573]
20:11:41.590 Active calls counted toward license limit: [571,573]
20:11:09.591 Active calls counted toward license limit: [571,573]
20:10:37.591 Active calls counted toward license limit: [571,573]
20:10:05.592 Active calls counted toward license limit: [571,573]
20:09:33.593 Active calls counted toward license limit: [571,573]
20:09:01.593 Active calls counted toward license limit: [571,573]
20:08:29.594 Active calls counted toward license limit: [571,573]
20:07:57.595 Active calls counted toward license limit: [571,573]
20:07:25.595 Active calls counted toward license limit: [571,573]
20:06:53.596 Active calls counted toward license limit: [571,573]
20:06:21.596 Active calls counted toward license limit: [571,573]
20:05:51.581 Active calls counted toward license limit: [571,573]
20:05:19.582 Active calls counted toward license limit: [571,573]
20:04:47.582 Active calls counted toward license limit: [571,573]
20:04:15.583 Active calls counted toward license limit: [571,573]
20:03:43.583 Active calls counted toward license limit: [571,573]
20:03:11.584 Active calls counted toward license limit: [571,573]
20:02:39.585 Active calls counted toward license limit: [571,573]
20:02:07.585 Active calls counted toward license limit: [571,573]
20:01:35.586 Active calls counted toward license limit: [571,573]
20:01:05.555 Active calls counted toward license limit: [571,573]
20:00:33.556 Active calls counted toward license limit: [571,573]
20:00:01.556 Active calls counted toward license limit: [571,573]
19:59:29.557 Active calls counted toward license limit: [571,573]
19:58:57.557 Active calls counted toward license limit: [571,573]
19:58:25.558 Active calls counted toward license limit: [571,573]
19:57:53.559 Active calls counted toward license limit: [571,573]
19:57:21.559 Active calls counted toward license limit: [571,573]
19:56:49.560 Active calls counted toward license limit: [571,573]
19:56:17.560 Active calls counted toward license limit: [571,573]
19:55:45.561 Active calls counted toward license limit: [571,573]
19:55:13.562 Active calls counted toward license limit: [571,573]
19:54:41.562 Active calls counted toward license limit: [571,573]
19:54:11.532 Active calls counted toward license limit: [571,573]
19:53:41.485 Active calls counted toward license limit: [571,573]
19:53:09.486 Active calls counted toward license limit: [571,573]
19:52:39.471 Active calls counted toward license limit: [571,573]
19:52:07.472 Active calls counted toward license limit: [571,573]
19:51:35.473 Active calls counted toward license limit: [571,573]
19:51:03.474 Active calls counted toward license limit: [571,573]
19:50:33.443 Active calls counted toward license limit: [571,573]
19:50:01.443 Active calls counted toward license limit: [571,573]
19:49:29.444 Active calls counted toward license limit: [571,573]
19:48:57.444 Active calls counted toward license limit: [571,573]
19:48:27.429 Active calls counted toward license limit: [571,573]
19:47:55.429 Active calls counted toward license limit: [571,573]
19:47:23.429 Active calls counted toward license limit: [571,573]
19:46:51.429 Active calls counted toward license limit: [571,573]
19:46:19.430 Active calls counted toward license limit: [571,573]
19:45:47.430 Active calls counted toward license limit: [571,573]
Does the system think there are live calls happening?
We are experiencing voice delay on this system - could this be a possible cause?
Paul
Hi Paul
Thanks for notifying us of this.
Can you send me the logs in verbose mode so I can see why calls 571 and 573 remained stuck?
I need to know the nature of these calls - whether they were normal internal calls, voip provider calls, gateway calls etc. This is why i need to see the logs. Send them to me [email protected]
Make a check for me as well and open the management console active calls page and see whether you see any extension or port/line orange.
Can you also send me a screenshot of the phones page with your email - so I can see whether you have duplicate registrations?
Hallo Nick,
my server log ist full of these messages. But there are no call-numbers in it?
This occurs after the update to V8. I use a small business license.
14:25:53.375 Active calls counted toward license limit: []
14:25:21.375 Active calls counted toward license limit: []
14:24:49.375 Active calls counted toward license limit: []
14:24:17.375 Active calls counted toward license limit: []
14:23:45.375 Active calls counted toward license limit: []
14:23:13.375 Active calls counted toward license limit: []
14:22:41.375 Active calls counted toward license limit: []
14:22:09.375 Active calls counted toward license limit: []
14:21:37.375 Active calls counted toward license limit: []
14:21:05.375 Active calls counted toward license limit: []
14:20:33.375 Active calls counted toward license limit: []
14:20:01.375 Active calls counted toward license limit: []
14:19:32.796 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 94.228.101.70:3478 over Transport 192.168.1.45:5060
14:19:29.375 Active calls counted toward license limit: []
14:18:57.375 Active calls counted toward license limit: []
14:18:25.375 Active calls counted toward license limit: []
14:17:53.375 Active calls counted toward license limit: []
14:17:21.375 Active calls counted toward license limit: []
14:16:49.375 Active calls counted toward license limit: []
14:16:17.375 Active calls counted toward license limit: []
14:15:45.375 Active calls counted toward license limit: []
14:15:13.375 Active calls counted toward license limit: []
14:14:41.375 Active calls counted toward license limit: []
14:14:09.375 Active calls counted toward license limit: []
14:13:37.375 Active calls counted toward license limit: []
greets
Patrick
this is normal. You have no active calls at the moment.
Read this post - answers are in it in the beginning.
Dear Nicky,
I have the same problem, like paul, I am also getting
Active calls counted toward license limit: [92]
could you find the solution for paul?
looking forward
Do you have an active call at the moment? It shows that call number 92 is still active.
Can you open the logs and search for Call(92) and copy all the log file here related to this call?
What is the nature of this call? Is it a gateway call? coming from PSTN?
Could be that because of improper configuration or incorrect routing the bye were not received and the call remained "Connected" when in reality it had been over a while ago. Let me know.
I have restarted the server, I will post again, if I will find it again the same situation
there was no active call, and log was showing for last 24 hours that ''Active calls counted toward license limit: [92]''
its mean system was stuck on call number 92,
call is made using PSTN Gateway, linksys 3102, and phone used to make this call is linksys spa941
Did you restart the configuration service? All Calls should be released at that point.
i suspected that its coming from a gateway.
I can tell you from now that I am positive that the problem is coming from there.
Check that disconnect tones in the linksys are compatible with the disconnect tone frequency expected by your pstn provider. You have to call your provider and speak to their engineering section. Tell them to tell you the frequency for the disconnect tone, and while you are there ask them for Dial tone, re-order tone and get your linksys up to date with your telco
This is the first area to need to fix.
can you please tell me what is the disconnect tone of CYTA?
we are using CYTA pstn lines there
i m using this for cyta before
425@-10; 10(0.25/0.25/1)
for Disconnect tone in spa 3102
YOu are in cyprus?
From where r u from?
On a grandstream I have connected in cyprus with primetel (also cyta applies)
this is the busy tone.
ch1-4:f1=400@-30,f2=400@-30,c=38/38;
for linksys I have this
480@-19;620@-19;10(.5/.5/1+2)
check it out and let me know.
Jake_Southern
