New User Interface - Call Logs Report
mark_sunnymanagementgroup
Extension or Range of Extensions is missing on the call logs report.
I need to export excel file to range of extensions. Unfortunately, can export per user only.
Hi there.
Indeed, there is no option in the interface in V20.
I don't want to export per users and we have lots of extension. what is your best suggestions to meet the goal below
Goal: I want to know unanswered calls and no call back to those unanswered calls for every department or range of extensions. This report is crucial to monitor the receptionist closely.
You cant specify the range of the users in the report.
Run Any-Any and export your CSV, and then you can parse it with the users you need.
Please provide guidance for a step-by-step tutorial.
There is no guide.Just use the csv tool you like and parse with the users you need.
I understand, but it's a hassle to export unanswered or missed calls for every user.
/dev/simon
