New V16 Debian Install No Console
copetek
I just setup another Debian 9 instance and installed 3cx like I have done hundreds of times before. Went through the web setup and configured the PBX. Now its time to go to the management site, and nothing. I check the services and all are running, I check the ports and all are good and listening on 5001. I check the install logs and all the others and nothing appears wrong. I can confirm the 3CX system is running from my reseller portal.
This is on Google Cloud Platform, the firewall ports are all open. I use the same tag for all the other PBX's running.
Just checking out to see if anyone has ran into this issue before?
I deleted the machine and rebuilt a whole new one and I was able to reproduce the issue.
I can't help on this, but i did a fresh DB9 cloud install on OVH using pbx express and didn't ran into this problem , everything is working fine.
Did you used pbx express too?
Hi @copetek
Have you tried logging on both via FQDN and via direct public IP?
Also curious if you are using the default Google Cloud Debian machine or some other image perhaps?
10531
I am using the default GCP Debian 9, after its up I run apt update/upgrade and then run the commands to install 3cx from apt. Everything goes as planned until I am done with the web 3cx wizard.
I have tried both fqdn and ip, I have not tried the internal up. I'll try that in just a few.
Update, after I posted the thread I left the machine and haven't checked until now. It appears after sometime it is working correctly now. I did check after the install if the fqdn was pointing to the correct ip and it was. So I do not know what the hold up was.
I think I am going to setup another one just to see if I can recreate the issue again.
Thank you,
Thanks for updating the thread, let us know how it goes.
Dame24
