New Yealink T54W Firmware failure
Pointy
New User
The New Firmware 96.85.0.5 locks out the WiFi when powered by a POE injector.
I had to restore a previous firmware level to get me handset working again, as i am not able to use a wired network while working from Home.
If anyone has come across this or has a fix?
Phil
You'd want to check the Yealink forums as 3CX has no control over the firmware. If it turns out it's a template configuration issue then come back here.
3K8iMGWviZ
