Solved No available outgoing trunks
Haiko buchholz
since Friday suddenly the 3CX fails creating calls to Telekom Germany SIP Trunk. I get the message " ...Ln.10001@Deutsche Telekom SIP-Trunk (NGN)) had no available outgoing trunk(s) for Call(856)". The other configured SIP Trunk (Easybell) works well. Incoming calls are also not working. What can I do?
Hello @Haiko buchholz
Are there any outbound rules in place that match the outbound calls from Deutsche Telekom?
Do you see the trunk as registered in the management console?
Yes. the trunk is registered an the rules are matching. As I said, the failure happened suddenly. Now, I asked the Telekom for reinitializing the trunk and at the moment it works. Thank you!
Glad to see the issue is now resolved. Keep an eye on the issue and let us know if you face the issue again
Mr_IT
