Solved no 'next' button in crm integration wizard
nick123123
Trainee Partner
hi, in the guide with crm integration it says to click the next button but there is no button?
Sounds like screen resolution issues, or your Windows install is messed up.
Definitely a screen resolution issue, you should try with a bigger monitor if your current setup can't be adjusted with higher screen resolution.
thank you i changed reslution and it worked
footandankle.my3fcx.us
