Solved No option to invite participants in Quick Meeting
ca_maer
When using the webclient and launching a Quick Meeting, according to this doc: https://www.3cx.com/user-manual/video-conferencing/ there should be a button to invite particiant in the upper right corner menu but I don't have such option. There is also no pop-up with the invite link when starting the meeting.
How can I get the link to the meeting to send to the participants ?
Our 3CX version is 18.0 Update 1
To get the link enabled, you need to set the user's Click2Meet settings as "Requires you to connect to meeting first". "Approve participants that join the meeting" might be needed as well.
That was it ! Thanks !
Graham Robertson
