No Remote Phonebook
tbc-tech
SOHO User
After we updated to version 20 none of our Yealink phones can "download" the remote phonebook. A user can still dial by the extension on which a phone is assigned to and that other phone will ring, but no one can lookup an extension to see who that extension belongs to, so they can make sure the correct person is getting contacted.
I saw where people have mentioned that this has to do with a certificate issue since version 20 has different security for provisioning. Others have mentioned that resetting the phones might fix it, but that would be very time consuming.
The phone models we currently have deployed are T22P, T23G, T31G, T40G all with updated firmwares. Any suggestions on how to get phones to "download" the remote phonebook in version 20 will be greatly appreciated.
Im facing the same issue but phonebook works with me if ip phone on the same vlan with 3cx server
Did you followed the manual? https://www.3cx.com/sip-phones/yealink-t20p-t22p-t26p-t28p/
In a local network the phonebook is pulled via HTTP
If you get that URL and enter it into a browser, you should ideally see the phonebook in XML format
For some reason your phone doesnt seem to have that access.
Things to check.
Firmware of the phone. Please be on the latest supported firmware from 3CX, not the vendor
Network routing allows HTTP(S) access from the phone to the PBX
Reactions: bitn2
Finatra.us
