Noobie -> 3CX v20 - w SBC - Twillio - GS2604P - WIN 10 ... Alberta, Canada
R.Gale
GS2604P - 3Cx - Twillio
Firmware 1.0.3.63
As well.... SBC running on my PC
Using a mix of CPE and have tried to trouble shoot via Web GUI/10.0.0.XXX
-> But am having FULL Connection issues with the device.... Grand Stream
Updates Time/Has Power/Populates with 3CX but does not have a full connection will actually ring and Register my accounts.
-> #DialPlan:
In Alberta, Canada ... our phone numbers are Local/Long Distance/Province Wide 403 780, 587, 825, 368
-> Local Call is 10 Digis .... 403 415 1488 .... Do I need to specify -> 1403 <- in Dial Plan creation .... Or just -> +1 <- & -> - 1 <-
#Question:
Is there known issues with the GS2604P...
Password Resets & Deleted .. then requiring a Factory Reset... only ending up in another LOOP
Please Link or Point me in the Direction you think might help,
Reach out ,
Comment.
Thank you
Richard
Hi Richard.
So in your case you are able to register your SBC, however then you wish to register device via that SBC and it fails?
Is the firmware of that phone the same as you can see here?
SG_F7
