Not able to add extensions via csf file
TecRivulet
Forum User
I've got a 3CX instance with existing extensions. I'm not able to create new extensions and/or update current ones using csv file. 3CX version is 16.0.504 on Professional product. Anyone knows the reasons and solution of it.
Please be a little more specific about the issue, for example, to you get an error you can share so we can understand?
