Not able to make outgoing calls
najib
I am new to 3cx and i'm trying to make an outgoing call. I have created my sip trunk and it's up and registered, i have also created an outgoing rule to route calls trough my sip trunk. But i can't make the call and i get the following.
SIP Server/Call Manager ID: 12294
Call or Registration to 0033184180834@(Ln.10000@OVH) has failed. 91.121.129.23 replied: 403 not registered; from IP:91.121.129.23:5060
Do you have an idea.
Thanks.
Hi najib,
According to your fragment it is not registered.
What type of trunk is it - IP Authenticated or Registration based ? if IP then it will show green regardless of whether it is actually registered or not, it does not matter.
Here is my trunk configuration, it is registration based.
OK then I find it impossible how your trunk would be green yet you are getting a failed registration message. Does your firewall check pass for ports and SIP ALG ?
You may need to include the Proxy settings also and could try using the public ip "91.121.129.23" as a test.
The firewall check didn't pass.
SaschaA_
