Unsupported Not able to upgrade to V18
amannick
Gold Partner
Hello Guys
I am not able to upgrade one of my 3CX instance to V!8 I have other instances which got upgraded in few clicks only but this one giving me hard time.
I have log as mention below any idea what should I do ?
Your 3CX Debian OS failed to update
3CX Phone System Management Console ID: 10012 08/15/2021 10:07:26 PM
Please help
Well that log snippet doesn't say much. I'd suggest trying again. Make sure you don't log in back into the Management Console while the update is running. Wait like 10-15 minutes.
You should be getting an email with a log file. Look at it and see if you spot any errors.
Check your free disk space too.
Hi @amannick,
Did you manage to update to v18 this time or is this still giving you a error?
@amannick can you PM me the Public ip address of the machine where you had this ?
Also, the upgrade failed or rolled back ?
Hello @NikosT_3CX and @VasilisV_3CX nope I have tried upgrading my 3CX instance to V18 multiple times but it never works. I waited for more than 45 mins but no luck
@amannick as per our private chat, if your machine has IPv6 enabled, send me this please as with IPv4 I can not find anything.
@amannick as per our private conversation, the main issue here is the following :
"Found an uncommon source list in /etc/apt/sources.list.d/: microsoft-prod.list - 0 [39m ::FAIL:: "
This is why your PBX never upgraded and always rolled back.
Remove this please and try again.
Hello Nick I removed it still I have issue
3CX attempted to update your 3CX Debian OS at ****t.my3cx.us from Debian 9 to 10 and failed.
@amannick as we discussed last night on the private chat :
There was also one more source list which you removed :
Found an uncommon source list in /etc/apt/sources.list.d/: pgdg.list - 0 [39m ::FAIL::
Now you are getting this :
[33m====== [15:16:51] Preparation: Preparing 3CX Backup: /var/lib/3cxpbx/Instance1/Data/Backups/rescueBackupUpgrade.zip[39m
System.UnauthorizedAccessException: Access to the path '/var/lib/3cxpbx/Instance1/Data/Backups/rescueBackupUpgrade.zip' is denied.
---> System.IO.IOException: Permission denied
[31m[15:17] Preparation: Backup script failed. Exiting - 0[39m
::FAIL::
I would highly recommend to check the rights on that specific path where backup writes and ensure that they are like this :
root@nikos:/var/lib/3cxpbx/Instance1/Data# ls -ld Backups/
drwxr-xr-x 2 phonesystem phonesystem 4096 Aug 17 23:59 Backups/
the system is no longer in a default OS configuration and therefore not covered by 3CX support anymore.
Take a backup of your current installation from the web interface, and restore this onto a new deployment clean deplyoment.
JamesAMB
