Notification Sound during calls (loud DING!)
Bob Thompson
Every conversation I have using the android client gives notifications approx every 30 seconds accompanied with the notification sound. This is very loud and very annoying. Happens on Wifi and 4G.
I joined the Beta group to see if running the Beta version of the app, might alleviate the issue. It did not.
- turning off app notifications does not stop the "DING"
- turning off ALL app notifications does not stop the "DING"
- setting the sound to Java did not work (nor OpenSL)
- finally, re-setting the phone, did not fix the problem
Same Issue: https://www.3cx.com/community/threads/annoying-notifications.56824/
Same as user "MartijnDoeland"
Device Info
Phone Model: [Samsung Galaxy Note 8 SM-N950W]
Firmware Version: [8.0.0 | 4.4.78-14503730]
Issue Info
Handset: [Phone]
Contacts: [Local|Exchange|Google]
Connection: [WiFi|3G]
Server: [Internal|External]
Phone:
3CX APP: Version 15.5.400.856
Android 8.0.0
Security Patch: 2018-11-01
Build: R16NW.N950WVLU5CRJ3
Open GL ES 3.2
Java VM 2.1.0
Not Rooted
Memory: 31% internal free and 50% external free
I have an idea of what this might be. Could you leave your phone locked for about 30 seconds and then unlock it and open the 3CX app?
Moments after the 3CX app opens and it's connected successfully, you hear the generic system notification sound?
Hi Leonidas,
((As requested, log sent, and it bounced [email protected], could you re-email me another address?))
I tried that and the 3CX app makes no sound (phone is not on mute) when it starts from a locked screen.
For good measure, I rebooted the phone and tried it again. Same result, no sound when 3CX logging in.
Bob
So the issue happens in the following case?
  1. Receive a chat.
  2. Phone loudly makes a 'ding' notification.
  3. You open the 3CX app to reply to the message.
  4. As the 3CX app connects, you hear another 'ding' notification?
No, sorry. When I receive a call or make a call. (Not Chat)
It can also go "bonkers" sometimes when I hang up after a call. 3? rapid "DINGS".
I've never seen this type of behavior. I think at this point we'd need to see some logs about this.
Could you go to your 3CX app > Settings > Advanced > Send Report right AFTER you've reproduced this issue once?
This will send us a log file of what exactly the app did and why it's doing this.
Hi Leonidas,
Your email bounced as it was from [email protected] Can you please re-email me with an address that will not bounce and I will send you the log.txt.zip
Thanks,
Bob
I've received the log, thanks.
I'll take a look when time allows and let you know.
Mahlon
