- Joined
- Apr 29, 2022
- Messages
- 1
- Reaction score
- 0
I am the developer of a custom CRM solution based on Django. My client wants to integrate with their 3CX version 18.0 (Build 461) Professional license, for CRM contact lookup.
I integrated "Django Oauth Toolkit" in our CRM to handle the authentication part.
Then we used 3CX CRM Template Generator to build a template for our custom CRM.
I couldn't find any developer documentation on what 3CX expects as Oauth2 settings like:
- Authorization grant type (I used Authorization code)
- redirect uri ( I found by looking at other integrations to use <FQDN>/api/oath2crm )
In the 3CX > Advanced > CRM Integration panel, I configured client-id, client-secret and used the "Authorize" button to get a refresh token.
If I then use the "Test" button to send a contact lookup, it works the first time, but never the second time.
I believe it has to do with refreshing the 'refresh_token':
When I "Authorize" and press "OK" to save the integration, it keeps working until the refresh_token expires.
When I log with wireshark I get this kind of conversation:
Notice that the refresh_token AgxHBbuhxHL8U3ki1bKoKORKI93uJp is the one that is visible under the Authorize button in the 3CX CRM Integration panel, but I don't see it in the logs with the server.
Is there something you expect differently from an Oauth2 perspective ?
Do you have more developer documentation ?
How can I keep 3CX in authorized ?
Code:
3CX -> CRM : GET o/authorize?response_type=code&client_id=<client_id>&redirect_uri=<redirect_uri>&state=<guid>
CRM->3CX: 200 OK: page with authorize button
CRM->CRM: POST /o/authorize?response_type=code&client_id=<client_id>&redirect_uri=<redirect_uri>&state=<guid>
+from with "allow"="authorize" etc.
CRM->3CX: 302: found, redirect with /api/oauth2crm?code=<CODE>
3CX->CRM: POST o/token/
code = <CODE>
grant_type="authorization_code"
client_secret=<client_secret>
state=<state>
CRM->3CX: 200 OK:
{"access_token": "bPBXm1Od22euUi4sWkaYdhBhZZGpEF", "expires_in": 36000, "token_type": "Bearer", "scope": "read write", "refresh_token": "b2w9n3ndEU3jsV4Iot5CN2Ec7KznV9"}
-- now 3cx has received a refresh token and will use it to get a new access token -- but forgets to update the refresh token
3CX->CRM: POST /o/token/
refresh_token=AgxHBbuhxHL8U3ki1bKoKORKI93uJp
grant_type=refresh_token
CRM->3CX: 200 OK:
{"access_token": "qmSAfOsnDxiAt4tMmr0BjZsDtDrVKw", "expires_in": 36000, "token_type": "Bearer", "scope": "read write", "refresh_token": "w9Z05yt3MMzTYmO38yn3HYKUUxT5bc"}
-- notice that the refresh token was updated !! --
3CX->CRM: GET /3cx/phonenumbers?phonenumber=5551234
Authorization: Bearer qmSAfOsnDxiAt4tMmr0BjZsDtDrVKw => this matches the access token above
CRM->3CX: 200 OK (nothing found: [] )
-- now trying TEST for the second time:
CRM->3CX: 400 Bad Request: error: invalid_grant
