Solved Office Hours for After Hours
mygeeknc
We have a DID that is used for after hours calls separate of our main DID. I only want the after hours DID to ring from 17:00 on a weekday until 07:59 the next morning. It doesn't appear that I can do this, the interface disables the OK button. What's the proper way to set this up?
Add 17:00-23:59, and then, 00:00-07:59.
Right, I thought about that too but I can put multiple times. So for example to do this correctly I'd need two times. 17-23:59 and 00:00 - 07:59 for each weekday. I can't seem to do that either.
You should be able to. Where are you doing this setting? Inbound rules or main system hours?
Inbound rules for this DID, the main system hours are set to 08:00 - 17:00.
You should be able to do this:
Can you confirm?
Reactions: ChrisC_3CX
I think I was having a brain fart, I thought it was asking me to change the existing time. Thanks for your help @Frederick Marcoux
devo.it
