On a Trunk Setup, have different inbound / outbound number of calls?
myrich33
When setting up a trunk, is it possible to have different inbound and outbound number of calls? For example, with one of my providers, I have 10 inbound call channels but only 5 outbound channels. I was thinking I could setup as two trunks to the same account, but it would be cleaner if I could just setup in one trunk. Thanks in advance, Rich
There's only one field on the trunk for limiting calls and it has no direction attached
Hi @myrich33
You could set this up as two trunks if your trunk set up allows it. If you are using a registration based trunk that is not possible unless you have 2 separate trunks. With IP based trunks this is possible if you have your call source identification set up correctly and inbound calls match the correct trunk.
This will require some testing to get right.
Netflo
