On Premises setupconfig.xml RequestCode = 'Language': Invalid reply
Bavesh MYT
Titanium Partner
We are having issue post update on the version 18.0.5.418 with the setupconfig.xml
The below appears but the correct code is not documented anywhere.
If someone has the right XML code for the correct language to assist.
Select language
(1) English (US)
(2) English (UK)
(3) German
(4) French
(5) Spanish
(6) Italian
(7) Portuguese
(8) Russian
(9) Polish
(10) Chinese
Enter option: PostInstall.InvalidAnswerException: Error in XML file. RequestCode = 'Language': Invalid reply
at PostInstall.MultipleColumnsSelect`1.RequestData(IConsoleWrapper console, SetupSettings settings, String defaultValue)
at PostInstall.LanguageRequest.RequestData(IConsoleWrapper console, SetupSettings settings, String defaultValue)
at PostInstall.MenuTree.GetInstallationSettings(MenuNode rootMenuNode, SetupSettings setupSettings)
at PostInstall.Setup.RequestSetupParametersAndExecute(String path, String[] commandLineArguments)
I would take a wild guess as follows:
<option>
<code>Language</code>
<answer>1</answer>
</option>
Would this be appropriate.
TVV40
