One way audio
Tomer
Once i'm doing the calls between app's everything is working fine.
Once i'm trying to work with call to deskphone (GXP1615 Grandstream) from the app- there is no audio for incoming calls to the Grandsteam, outgoing calls are working and both sides can hear, but call is getting disconnected after every 30 seconds.
Please advise.
Suspect several sets, using STUN, behind a router....which doesn't always work correctly, even if each set is assigned a unique local SIP port. Could try "PBX delivers audio" option, on each extension, or the use of an SBC at the site
One way audio issues are mostly always a networking issue (firewall most likely) so first be aware of the ports that are required, and as @JohnS_3CX says provide more information in regards to setup.
https://www.3cx.com/docs/ports/
Wecare_ITA
