onging issue with smartnode 4960
actualy it is changed, box restarted and stillusing that ip no idea how to get rid of it
Jeremy,
I would suggest that you get a commercial edition with a support package. You have a fair amount of tech queries and i believe getting paid tech support would help you.
thanks for that, however we already have a paid eddition with support, unfortunatly the support is not helping much at all
Hi there
Did you open a support ticket for this?
If not, please do so to allow us to handle this correctly.
The patton network interfaces are coming up and down repeatedly which means that you have a network configuration issue.
Regards
Kevin
no we have never been provided with a method to create a ticket
Hi there
Please PM me your license key so I can investigate this issue.
Thanks and Regards
Kevin
I just tried to configure my 4960 following the instruction you are recommend on this site but i just get the same error message in the boot log :
tarting Modules...
2000-01-08T01:11:41 : Pwr off/Man reset
All modules successfully started
Config startup-config READ [ OK ]
Config startup-config EXECUTE 2000-01-08T01:11:48 : LOGINFO : Link up on interface ethernet 0 0 0
[FAILED]
2000-01-08T01:11:48 : LOGWARNING : Config: Line 59: SN4960/4E30V(pf-sip)[default]#no autonomous-transitioning
2000-01-08T01:11:48 : LOGWARNING : Config: % ^ Keyword mismatch
2000-01-08T01:11:48 : LOGWARNING : Config: Line 107: SN4960/4E30V(if-sip)[IF_SIP_0]#bind gateway GW_SIP_0
2000-01-08T01:11:48 : LOGWARNING : Config: Line 110: SN4960/4E30V(if-sip)[IF_SIP_0]#service default
2000-01-08T01:11:48 : LOGWARNING : Config: Line 112: SN4960/4E30V(if-sip)[IF_SIP_0]#remote-party-id called-party
2000-01-08T01:11:48 : LOGWARNING : Config: Line 117: SN4960/4E30V(if-sip)[IF_SIP_1]#bind gateway GW_SIP_1
2000-01-08T01:11:48 : LOGWARNING : Config: Line 120: SN4960/4E30V(if-sip)[IF_SIP_1]#service default
2000-01-08T01:11:48 : LOGWARNING : Config: Line 122: SN4960/4E30V(if-sip)[IF_SIP_1]#remote-party-id called-party
2000-01-08T01:11:48 : LOGWARNING : Config: Line 127: SN4960/4E30V(if-sip)[IF_SIP_2]#bind gateway GW_SIP_2
Are you sure that you are really generating a configuration file which is compliant with the firmware R5.1 ?
br
Bertrand
Hi Bertrand
The config file you are using is for a R4.2 firmware.
Regards
Kevin
KasunJay
