Ongoing calls Hangup during submit
harsh
I am using sip trunk to connect elastix 2.4 to outside.
Whenever I change some settings through elastix GUI (for e.g added new sip extension) and submit & apply configuration changes, all calls hangup while reloading.
But whenever I reload it from Asterisk CLI it wont disconnect the calls.
What can be the possible solution?
harsh,
Sir what version of Elastix are you using?
Thank you,
amphibian
Here is my configuration details,
Kernel
Linux(x86_64)-2.6.18-371.1.2.el5
Elastix
elastix-2.4.0-8
elastix-a2billing-1.9.4-5
elastix-addons-2.4.0-10
elastix-agenda-2.4.0-14
elastix-asterisk-sounds-1.2.3-1
elastix-email_admin-2.4.0-6
elastix-endpointconfig2-2.4.0-2
elastix-extras-2.4.0-5
elastix-fax-2.4.0-4
elastix-firstboot-2.4.0-4
elastix-framework-2.4.0-19
elastix-im-2.4.0-2
elastix-my_extension-2.4.0-6
elastix-pbx-2.4.0-18
elastix-portknock-0.0.1-0
elastix-reports-2.4.0-10
elastix-security-2.4.0-9
elastix-system-2.4.0-13
RoundCubeMail
RoundCubeMail-0.3.1-12
Mail
postfix-2.3.3-6.el5
cyrus-imapd-2.3.7-12.el5_7.2
IM
openfire-3.7.1-1
FreePBX
freePBX-2.11.0-17
Asterisk
asterisk-11.13.0-0
asterisk-perl-1.03-0
asterisk-addons-11.13.0-0
FAX
hylafax-4.3.10-2rhel5
iaxmodem-1.2.0-2
DRIVERS
dahdi-2.10.0.1-0
rhino-0.99.6-3.b4
wanpipe-util-7.0.10-2
Thanks,
Harsh
harsh,
Sir, I am inclined to believe that it may be a "bug" you have found in the software in the way they have it saving the inputted results, although I could be wrong.
You may want to file it as a bug report and see where it takes you from there. I myself not having that issue, I am using 2.4.0.2 and that maybe where it is at as you are using 2.4.0.8. I also have 2.5 on the test bench and tried what you described and didn't see it doing the issue either.
amphibian
Do you have any solution for this problem?
I cant afford to change to elastix 2.5 :?
Sir harsh,
I would submit it as a bug report and see what feed back you get.
You can submit that at: bugs.elastix.org
No need to upgrade to 2.5 at this point for something that may be a simple fix.
amphibian
Dear amphibian,
Thanks for help & keep me informed after getting feedback from Elastix.
Thanks,
Harsh
eokwaro
