Only one trunk disable - Possible?
RemoMeyer
Hello
In Trunk menu we have the possiblity of "Disable All" or "Enable All", but we need a only one Trunk disable. Can we do this? There are a Workkaround?
12709
PS: We need this as a backup. We have a "Backup Instance" with Inbound Rules as "Forward an Outside Number", in case of anything happens with the First Instance. have you may any best Ideas?
PS2: Failover isn't a option.
The work around is you add a few zeros to either the SIP server, username or password then it will not register. Probably do it to the server, that way your SIP provider wont blacklist you.
Yes, I already do this. Problem is, with this Workaround we have Thousand Erros in Log.
It's a solution, but isn't "clean". I think that a "so little" thing is, weird that there aren't a option "Disable one" or something so.
Export provider, remove it from your console, add it when you want it again.
It's like Windows errors in event log. If it aint broke..
So, there are other points that we need be careful: inbound Rules need to be "connected" when we import. But yeah, looks like save as a file and import when needed it's the best solution today.
Wecare_ITA
