Options go to the same menu
JorgeWillianSantos
Hello, is there a way to get two different options to be sent for the same configuration? I want the restaurant options to be directed to the same menu without having to create two different menus, is it possible?
Create your menu in a User Component, the use that component in the two places and you'll have 1 menu to manage.
Can you tell me if this also works for voice input?
Yes, if you define a User Defined component, that component can be called from anywhere in your CFD app. From the branches of the Voice Input component too.
ARKC
