Outbound call
Marco89
Hi all,
i have a problem with outbound call.
When i make a call and the number is busy the system answer me with code 486 Busy Here if i make a call to a non-existent number the system answer me with the same code 486 Busy Here, but is a problem because my operator can't understand the difference on telemarketing operation.
there are any solution to avoid this problem?
thanks
Hello @Marco89
Please note that this depends on what the provider sends back to the system when you make an outbound call. If the same error code is sent by the provider in both cases then you will the same message in the phone system.
Hello @Marco89
ok then there are no solution
there are any option to enable busy tone for my problem?
WagnerFT
