Outbound Caller ID as 12345651 but it showed Caller ID 12345680
Sean Png
I set Outbound Caller ID as but it showed Caller ID when I dialed another DDI No. or an external mobile number.
My DDI number is
is the SIP Trunk provided by myRepublic.
Please assist. Thank you.
Hello @Sean Png
The first thing i would recommend is to not share personal data in public forums. Regarding the issue are you using the default 3CX template? Also is your outbound caller id a DID given to you by myRepublic?
The big question...does your provider allow you to change outbound caller ID to something other than the "main" billing number, provided by them? I would confirm that before proceeding.
SaschaA_
