Solved outbound calls not working
villagrandrealestate
I have 5 voip Portuguese numbers with zadarma.com
I set the Trunks in 3cx, and for incoming calls everything works fine, however I cannot make outbound calls.
I always get this error:
There was no user or outbound rule found for the number +35128***** that Ext.13 dialed.
If I set an outbound rule that is triggered when I call, is not working and on call log I get "No existing route". Thank you in advanceCaptura de ecrã 2024-05-26, às 13.26.23.pngCaptura de ecrã 2024-05-26, às 13.09.49.png
Is this the only outbound rule that is configured?
Yes, thank you for your reply. We have have found the error(we were using the VOIP number as Main Trunk Number instead of the SIP number)
Glad to know this is resolved. ;)
tohoken1
