Outbound Calls on 3cx Startup Pro
ethan.mcdonnell20
New User
I have added a SIP trunk to my 3cx StartUP instance and it is configured properly, Inbound calls on the SIP trunk are working but when trying to make a Outbound call from any device it comes back with the error Forbidden. Any help is appreciated.
Thank you very much. I have a number with clouditalia tomorrow I will call them!
Hello, I inform you that clouditalia has no problems, the technicians told me that the problem is only yours .... how can I solve it? Is it perhaps the startup solution that doesn't work^ can I change it? because otherwise it doesn't make sense that I have a switchboard that doesn't work!
I suggest contacting a 3cx partner to assist you with this https://www.3cx.com/ordering/find-reseller/ or opening a ticket with us here at 3cx techical support from your customer portal, portal.3cx.com, for us to check for you.
@Samanta, you may also try removing the +39 from the beginning of the main trunk number and leaving the number in national format instead of E164 international format and let us know.
I have sent you a pm. Can you check and follow the instructions, please?
Hi Charles, I have exactly the same issue on my 3CX hosted Startup Pro, inbound and internal calls work fine, just recieve the "Forbidden" when dialing to an external number. I would appreciate if you would be able to forward the instructions as they seem to have resolved it for other users. Many Thanks
You will need to open a ticket with tech support, please, as each case is different, and there is no one size fits all solution.
Netflo
