Solved Outbound Issues
smith13045
So I am new here and trying to get 3cx setup for testing. I am currently having issues with Outbound calls. I have an outbound rule but when I make a call it fails and I have an error in the logs
Cause: 404 No destination/INVITE from
I am using DIDLogic as the SIP Trunk Provider.
Any help will be great.
If the message is from your provider (the part you left off...after the from), then, it suggests you are not sending a valid number. Be sure that your rules are correctly striping any access digit(s) you may use.
Call to T:Line:10000>>xxxxxxxxxx@[Dev:sip:[email protected]:5060] from L:18.1[Extn:1005] failed, cause: Cause: 404 No destination/INVITE from 107.6.13.77:5060
So the 107.6.13.77 is my SIP Trunk Provider.
my area code is 503. Should I be doing a 1503 when I dial or just 503?
I got it working. Thanks for your help
Glad to see the issue has been resolved. May i ask what the solution was so other users might benefit from your answer?
WAFI
