Hello guys, I'm facing issues with configuring outbound rules. Can someone help me with the way I should write them?
I have a GOIP gateway connected to a local sim card (Lebanon) the country code is +961 and our numbers are in this form (78 XXX XXX) or (03 XXX XXX).
Thank you in advance!
How you will implement the Outbound Rules here might depend on a number of things such as, what your users are used to dialing, what called numbers your SIP Provider allows, what calls you want to allow, etc, so before doing anything, I first recommend having a look through our training material regarding outbound rules here: https://www.3cx.com/3cxacademy/videos/basic/configuring-voip-providers/
(Slides 9-11)
By better understanding how they work you will then be able to identify what information you must gather to determine how to configure them to suit your needs.
