Sorry for the bad explanation, I'm trying to make an internal call to another extension, when call to 123 automatically this becomes in this +15555557777;ext=123. and it says the call couldn't be completed.Can you please clarify... this is the caller ID you are talking about?
You are making an internal call, to another extension, not a call using the outbound rules, and the called party doesn't simply see the extension number?
Do you have the Teams integration enabled by any chance?Sorry for the bad explanation, I'm trying to make an internal call to another extension, when call to 123 automatically this becomes in this +15555557777;ext=123. and it says the call couldn't be completed.
Thanks.
No.Do you have the Teams integration enabled by any chance?
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
