Solved Outbound rules extension number
EdoF
I can't figure out what is wrong with my outbound rules.
When I dial from extension 702, to a number starting with 49, the 6th rule should be selected(see attached screen shot), however, the log states 'no matching outbound rule found'.
When I add extension 702 to the rule, the correct rule is selected, I didn't think it was required to add extensions to all the rules.
Any hint or suggestion would be most appreciated.
Edo
Make your rules less complicated, unless it is required remove length and extension group from the rule
Is extension 702 part of the extension group
Thank you Saqqara, indeed, to many outbound rules, and because of that I no longer saw that I had even added extension groups to the rule, that was the problem.
Reactions: ChrisC_3CX
Glad to see you managed to sort this out!
Do not hesitate to post anew should anything else come up.
Reactions: EdoF
apbGroup
