- Joined
- Feb 19, 2014
- Messages
- 81
- Reaction score
- 10
I have create a group with many extensions in it. I have created an outbound rule that uses this group to block access to using long distance number. I have discovered that if the long distance dialed is 19873130478 and that I have an extension that is 1304, it will use that outbound route because it seems to find 1304 in the number 19873130478. Is this a confirmed bug or is this normal ?
Is there a workaround ?
Thanks.
Marco
Thanks.
Marco
