Solved Outgoing calls fail (SIP trunk)
Artem Khvostenko
New User
Hi I have Kyivstar SIP trunk, it registered, but I can't make outgoing call
- non via Android 3CX
- non via MS Teams (Direct routing)
Meanwhile inbound call work in both way.
Check your provider has allowed outbound calls and check your invite format.
Reactions: Artem Khvostenko
Hi @Artem Khvostenko
It looks like you are getting a forbidden message from your provider so make sure that you are dialing numbers in the correct number format. Also make sure you are using the default 3CX template which has the correct outbound parameters.
If everything looks correct on the 3CX side then contact your provider and ask them why the calls are being rejected.
Hi, thank you for reply. SIP provider asked me example call and call trace, I don't know where I can find call trace.
You can navigate to Dashboard / Activity log and start a capture from there.
Make your test call/calls and stop the capture from the same screen. You will then get an option to download the pcap file from the following menu.
Save it and send that to your provider.
SIP provider learned captured log and said me that I have incorrect field
from
I have +380443912224
Need 443912224
So I changed in MS user work number and now can call from 3CX-Android-app
But still no from MS Teams, because somewhat added "+" to my work number in MS Teams
Like you can see on video when MS Teams is opening
from withot "+"
and after moment with "+"
vieo4.mp4
What can be reason? Dial Plans in MS Teams, but they was pushed from 3CX to Teams via Powershell.
# Note: office phone number should start with a '+' and have from 2 to 15 digits
# If it's invalid please correct it in the Microsoft365 user settings
Set-CsPhoneNumberAssignment -Identity [email protected] -EnterpriseVoiceEnabled $true
Set-CsPhoneNumberAssignment -Identity [email protected] -PhoneNumber "443912224;ext=100" -PhoneNumberType DirectRouting
Set-CsPhoneNumberAssignment -Identity [email protected] -PhoneNumber "443912224;ext=101" -PhoneNumberType DirectRouting
$users_ids = @("[email protected]","[email protected]")
New-CsBatchPolicyAssignmentOperation -PolicyType TenantDialPlan -PolicyName "3CX Dial Plan" -Identity $users_ids -OperationName "Batch assign dial plan"
New-CsBatchPolicyAssignmentOperation -PolicyType OnlineVoiceRoutingPolicy -PolicyName "3CX Voice Route Policy" -Identity $users_ids -OperationName "Batch assign voice routing"
New-CsBatchPolicyAssignmentOperation -PolicyType TeamsCallingPolicy -PolicyName "3CX Calling Policy" -Identity $users_ids -OperationName "Batch assign calling policy"
Install-Module -Name MicrosoftTeams
Connect-MicrosoftTeams
New-CsOnlinePSTNGateway -Fqdn sbc.softico.ua -Enabled $true -SipSignalingPort 5062 -MaxConcurrentSessions 100 -ForwardCallHistory $true -ForwardPai $true
Set-CsOnlinePstnUsage -Identity Global -Usage @{add="3CX PSTN Usage"}
Set-CsOnlinePstnUsage -Identity Global -Usage @{remove="All"}
New-CsOnlineVoiceRoute -Identity "3CX Voice Route" -NumberPattern "^((\+\d+)|(\d{2,5})|(\*0\d)|(\*1\d)|(\*1\d\d{3})|(\*20\*)|(\*20\*\d{3})|(\*3[0-4])|(\*4\d{3})|(\*62)|(\*63)|(\*9\d{3})|(\*9\d{3})|((\+)?\d+\*\*\d+)|(\*64[1-2])|(\*5(\+)?\d+)|(\*68\d)|(\*777)$|(\*888))$" -OnlinePstnGatewayList sbc.softico.ua -OnlinePstnUsages "3CX PSTN Usage" -Priority 1
Set-CsOnlineVoiceRoute -Identity "3CX Voice Route" -NumberPattern "^((\+\d+)|(\d{2,5})|(\*0\d)|(\*1\d)|(\*1\d\d{3})|(\*20\*)|(\*20\*\d{3})|(\*3[0-4])|(\*4\d{3})|(\*62)|(\*63)|(\*9\d{3})|(\*9\d{3})|((\+)?\d+\*\*\d+)|(\*64[1-2])|(\*5(\+)?\d+)|(\*68\d)|(\*777)$|(\*888))$" -OnlinePstnGatewayList sbc.softico.ua -OnlinePstnUsages "3CX PSTN Usage" -Priority 1
New-CsOnlineVoiceRoutingPolicy "3CX Voice Route Policy" -OnlinePstnUsages "3CX PSTN Usage"
New-CsTeamsCallingPolicy -Identity "3CX Calling Policy" -AllowVoicemail "AlwaysDisabled"
New-CsTenantDialPlan -Identity "3CX Dial Plan" -Description "3CX via Direct Routing"
$TCXExt = New-CsVoiceNormalizationRule -Parent Global -Name "3CX Internal" -Description "Dialing 3 Digit Extension" -Pattern '^(\d{3})$' -Translation '$1' -IsInternalExtension $false -InMemory
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXExt}
$TCXUnPartAny = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Unpark Any" -Description "DialCode Unpark Any" -Pattern '^(\*1\d)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXUnPartExt = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Unpark Ext" -Description "DialCode Unpark Extension" -Pattern '^(\*1\d\d{3})$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXPickUpAny = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode PickUP Any" -Description "DialCode Pickup Any" -Pattern '^(\*20\*)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXPickUpExt = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode PickUP Ext" -Description "DialCode Pickup Any" -Pattern '^(\*20\*\d{3})$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXProfileChange = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Profile" -Description "DialCode Profile" -Pattern '^(\*3[0-4])$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXVboxOfUser = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Vbox Call" -Description "DialCode Vbox of User" -Pattern '^(\*4\d{3})$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXQueueIn = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Queue In" -Description "DialCode Queue LogIn" -Pattern '^(\*62)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXQueueOut = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Queue Out" -Description "DialCode Queue LogOut" -Pattern '^(\*63)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXPaging = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Paging" -Description "DialCode Page Ext" -Pattern '^(\*9\d{3})$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXBilling = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Billing" -Description "DialCode Billing" -Pattern '^((\+)?\d+\*\*\d+)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCX3cxStatus = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Office" -Description "DialCode Office" -Pattern '^(\*64[0-2])$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXCallerID = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode CallerID" -Description "DialCode Hide CallerID" -Pattern '^(\*5(\+)?\d+)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXHotel = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Hotel" -Description "DialCode Made Codes" -Pattern '^(\*68\d)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXEchoTest = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Echo" -Description "DialCode Echo Test" -Pattern '^(\*777)$' -Translation '$1' -IsInternalExtension $false -InMemory
$TCXCallTest = New-CsVoiceNormalizationRule -Parent Global -Name "3CX DialCode Call" -Description "DialCode Call Test" -Pattern '^(\*888)$' -Translation '$1' -IsInternalExtension $false -InMemory
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXUnPartAny}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXUnPartExt}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXPickUpAny}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXPickUpExt}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXProfileChange}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXVboxOfUser}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXQueueIn}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXQueueOut}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXPaging}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXBilling}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCX3cxStatus}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXCallerID}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXHotel}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXEchoTest}
Set-CsTenantDialPlan -Identity "3CX Dial Plan" -NormalizationRules @{add=$TCXCallTest}
Hi Artem,
The communication between 3CX and Teams must be in the E164 number format so all numbers must start with "+".
If your provider does not accept an E164 caller ID then I would recommend setting a fixed caller ID in the outbound parameters in the format your provider wants it.
All calls will have the came caller ID this way but all calls will work.
It was made yesterday.
I set caller id in outbound rule, but it doesn't help
Having the outbound rule in place can you make a call and check the activity log of the PBX for the Invite to the provider? Does the PBX send the correct caller ID to the provider?
You may need to set it to Verbose logging to get the full details of the call.
I can call from MS Teams to external numbers.
Thank you for help
Good day
Reactions: YiannisH_3CX
tohoken1
