Solved Outlook Integration with 3CX Free
smartek
Is it possible ? I cannot click in "Enable Integration"
Kind regards,
Stephane
Hello @smartek
You will need to download a plugin to integrate outlook with you client in the Standard version of the PBX. Integration is available in the PRO and ENT version. More info and the link to download it can be found here:https://www.3cx.com/docs/microsoft-outlook/
Hi YiannisH,
Thank you for your answer. It did help, but I humbly think that the link https://www.3cx.com/docs/microsoft-outlook/ is misleading for the Standard version, as the screenshots and most of the explanation are for Pro and Ent version. Anyway, just install the plugin on the client pc manually, fire up Outlook and you are good to go :).
Glad i could assist and thank you for your feedback regarding the guide.
apbGroup
