Partner portal issue
crenegar
Greetings - When logging in to the partner portal I have an old install that was a test. It has since been replaced by a licensed account, how can we make the old one disappear? Seems like this should be easy but I can't find it. Thanks...
When you login to the partner portal there should be a link to the partner service center. That's who you want to contact.
The correct way would have been to upgrade the existing license (test) then buying a new one.
Anyhow, you can contact our customer service team to remove this license for you.
hughesdouglas
